What the best 383 twin turbo heads/cam
Hi I am building a 383 stroker and doing a twin turbo set up. I plan on running up to 18 psi of boost. My goal is to get into the 700s rwhp. I have a fully ported intake. bottom end should be good for lots more. I just need to figure out what heads and cam to get. whats the best combo ? or really good combo.
AFR 210s ?
AFR 210s ?
Contact Advanced Induction, if you ask nice they should be able to keep the power that LOW. Believe they have several cars well over that number on ported stock castings
AFR would be my last recommendation. If you need a big chamber the Trickflows would be the best choice.
I would consider finding a virgin intake and either use it as is or send it out with the heads to the same porter.
