Can ignition go bad?
Old 10-30-2007, 05:36 PM
Red96TA's Avatar
Default Can ignition go bad?
Can ignition parts (ex. opti, coil, wires etc) go bad from sitting for say two years?
Old 10-30-2007, 05:48 PM
Gun5's Avatar
moisture
Old 10-30-2007, 06:53 PM
95zpro's Avatar
yeah, moisture could probably get into the opti etc. Also hopefully you drained your tank or added some stabil to it.
Old 10-30-2007, 07:33 PM
Red96TA's Avatar
Well it didnt have very much gas in it when it was sitting up (before i had it anyways so idk if they put stabil in it?) But i put like 3/4 of a tank of good gas to mix in if it had bad gas anyways with some injector cleaner and stuff. One more question....If im not getting spark at all when I pull the #1 plug wire and put it on the header with a screwdriver could that be the ICM? or would that just be an opti/coil related.
