In Despret Need Of Help
i have a problem with my trans i think or somthing no one noes exactly what it is so here it is i start my car and it fine shifts into first and then to second a little hard then once it gets to about 3500 rpm in second gear it just revs up and wont shift and i have like no power going to the wheels at all also my fuel pressure drops to like 20psi from 40psi and stays like that for a while then it goes to normal any body have any ideas
Might be a dead tranny... try manually shifting into second, once you reach about 3000 shift it into 3rd. If it just revs and doesnt go into gear, drop it back into second. If it shifts back into second then you only have 1st and 2nd gears. If thats the case your trans is most likely shot.
see that the thing i just put 2500 into the trans and its only got about 3000 miles on it and i never really beat on it and when i tried taht it didtn even shift to third just stahled up wen it hit 3000rpm
