Setting up fuel system for 383ci LT1
Im piecing together a 383 LT1 setup and am trying to figure out how i should go about fueling this bad boy.
Heres some specs:
383ci
circa 10.7:1 CR
1.5 RR's
230/236 576/572 113 lsa custom grind cam
stock casting ported/polished heads
and the infamous comp 918's
M6 car
4.10 rear
I guess my real question is can i stick with the stock injectors and fuel pump or is this motor going to want more than what the stock stuff can dish out? If i have to upgrade.. What size injectors would be best and what fuel pump should i be looking for?
Thanks
stan
Heres some specs:
383ci
circa 10.7:1 CR
1.5 RR's
M6 car
4.10 rear
Thanks
stan
I run the stock pump (Almost 13 years old) and 30lbers in my set up...My cam is a 226/234 and is a wee bit smaller in lift, though...When the stocker quits I'm going to go with the Racetronix plug and play set like Speed Density suggests, but I think the stock and 32s or 36s would be fine for now...
--Alan
--Alan
well good thing my thread was not about asking YOU what cam i should put in my car. that cam was specced by a speed shop in my area with my goals and car in mind that has built and raced more cars then they know what to do with. thanks for your insight and answer to my original question though.
i have a 383 lt1 with about the same mod to it as u and i run 255 in tank pump ,36# excel inj ,adj regulator ,and custom tune and run 7.51 on all motor and have enough fuel to run a 350 shot on top of that, and a/f was checked on the dyno.
