ls1 k&n on my 94 z!!
Old 12-18-2007, 01:02 PM
mean94lt1's Avatar
Default ls1 k&n on my 94 z!!
just finished it up yesterday i attached some pics...
Attached Thumbnails ls1 k&n on my 94 z!!-94-z-013.jpg   ls1 k&n on my 94 z!!-94-z-014.jpg   ls1 k&n on my 94 z!!-94-z-015.jpg
Old 12-18-2007, 01:06 PM
porksoda's Avatar
I don't want to be a downer but thats the same thing as putting a filter on the end of your throttle body. Except you probably paid $150 more.
Old 12-18-2007, 01:09 PM
Tireburnin's Avatar
At least cut air holes.
Old 12-18-2007, 01:19 PM
speed_demon24's Avatar
What kind of hood do you have?
Old 12-18-2007, 02:13 PM
mean94lt1's Avatar
its a glasstek 4 inch cowl and i got the setup used so it was cheap...
Old 12-18-2007, 02:18 PM
mean94lt1's Avatar
isnt that what your supposed to do?...and not sure why you would even say this to anyone why cant everyone just be nice on here?
Old 12-18-2007, 03:35 PM
porksoda's Avatar
Don't take it wrong it's a cool idea and all but it's not functional. LT1's don't take in air from the front air dam. They take it from the fender well so basically you will be sucking in all that hot air under the hood which is what a CAI is NOT supposed to do.
Old 12-18-2007, 03:51 PM
qwk93ta's Avatar
This is my setup and it did improve my 1/4 mile .1 or .2 if I remember right. I can't find my time slips right now.
http://s229.photobucket.com/albums/e...1Image0034.jpg
Old 12-18-2007, 04:27 PM
Whitez406's Avatar
Looks good, everyone else iwth the ls1 filters seems to pick up a tenth or 2 so i must be doing something up there.
Old 12-18-2007, 04:28 PM
Revelation Z28's Avatar
if you had an ultraZ hood that FIPK would be great.
if it wouldve fit under the front of the cowl, you couldve done a lid for the same price as the FIPK.
Old 12-18-2007, 04:32 PM
Moderator
BizZzatch350's Avatar
I'm interested in how you got your IAT sensor set up, did you just pull it from the intake elbow and stick in the new bellow?
Old 12-18-2007, 04:37 PM
mean94lt1's Avatar
the iat was in a aftermarket trickflow elbow already and i cut a hole in the bellow and fit it in and siliconed the inside around the sensor
Old 12-18-2007, 04:39 PM
as a suggestion, if you dont care much about the radiator cover, you can cut some of it out and slide some rubber around the edges to smooth them out so air can be fed from the bottom of the filter. then add FTRA later on to scoop it up there.
Old 12-18-2007, 05:06 PM
registered user
ScreaminRedZ's Avatar
Definitely unique, but I agree that a lid setup would probably be better for hp. If you put it on the dyno to judge gains, make sure the hood is closed.
Very clean install!
Old 12-18-2007, 05:09 PM
Ls1Bait's Avatar
Im trying to figure out if you can put a complete LS1 air lid and bottom on with a Glasstek 4 inch cowl. I figure if im going to by a hood I mine as well get one that I can use the LS1 air induct system with.
Old 12-18-2007, 05:17 PM
mean94lt1's Avatar
i do plan on fabbing the rad support that came with this kit so under the air cleaner is cut out just havent figured out how im going to do it yet....
Old 12-18-2007, 08:48 PM
96lt1m6's Avatar
i would hurry and cut a hole in the shroud for sure cause at this point you are getting no true cool air,better yet if you build one from thin aluminum cut a hole the size of the filter polish it up,i think that woold look good and perform pretty well......
Old 12-18-2007, 08:54 PM
the_merv's Avatar
I can see it working with a Cowl Hood..but not as effectively as you want it too..
Old 12-18-2007, 09:03 PM
FASTFATBOY's Avatar
The LS1 lid gains on an LT1 have been debated here before. Actual dragstrip testing with a NON ws6 style hood netted little or no gains. Do a search.
IMO aint worth the trouble.
BUT, his setup would work with a sheetmetal box that sealed to the hood and was open on the front to get air from the hoodlatch area.
David
Old 12-18-2007, 09:33 PM
Whitez406's Avatar
One of the reasons he moved it was to make a nice engine bay mount point for the msd 6AL, not just that he wanted the ls1 intake for a gain of power. I believe its pretty sweet and can be made to be functional. Sucking air thru the fenderwell sucks in the rain it tends to get wet its just easier with a setup like this.
Quick Reply: ls1 k&n on my 94 z!!
