Big NA cam with boost? 242 / 248, .584 / .579 113 LSA
I have this cam already. I'm about to boost my car. Shooting for 10lbs with meth injection. I don't know anything about blower cams other than the duration always seams to be smaller and I hear bigger duration lets the boost "bleed off" Is my cam way to big? Will it work at all or should I tear apart my motor now and sell it and just get a custom ground cam. I
I love this cam in my car NA though. 383 with stock heads and I was shifting at 6900. I would love to keep my power curve up high like it is now with the Turbos.
What you guys think?
63-224/236-114 Comp Cams "Extreme" LT1 Camshaft, 224 / 236, .502 / .520 114 LSA, Very aggressive camshaft for street/strip blower applications. Heads, Exhaust, Stall or M6, Computer tuning required $269.99
Here is the blower cam specs. Thunder racing carries it.
That's not exactly correct. I have the same ca but on a 114 i'm boosted, and it makes good power and good boost. however I'm running a D-1SC and if i understand it correctly that centrafugal blowers like bigger dur. so you might be in a different boat with the turbo.
113 LSA is a compromise anyway, it is not an "NA" cam as it is. It won't be as ideal as a custom blower grind, and is a bit on the large side, but it should still make tons of power
