Which injectors for my 383
Old 02-06-2008, 03:53 PM
tscheu5452's Avatar
Default Which injectors for my 383
I'm told that I need bigger injectors for my 383 project. The Ford SVOs seem to be the most popular. I would like to get some 36lb injectors, but can only find them in 30 or 42. I've read that on an LS1 the stock fuel pressure is 58lbs and using the Ford SVO 30lb injectors is the same as using 36s. But I think the fuel pressure on an LT1 is around 45lbs so this wouldn't work. Right? Hopefully someone can steer me in the right direction.
Old 02-06-2008, 03:57 PM
94'BLKBRD's Avatar
36lbs should be enough
Old 02-06-2008, 04:04 PM
Stroked96Bowtie's Avatar
Got Lucus 42#s going on mine...little overkill prolly but the inj should be able to operate comfortably without pushing it. It also opens up your options and some fuel to 'grow' into for power adders etc.
Good luck!
Old 02-06-2008, 04:20 PM
Rocky70304's Avatar
30lb injectors will work fine on a 383, u can use the 42 lb injectors like stroked said if you have any future plans for power adders..
Old 02-06-2008, 06:06 PM
Mojave's Avatar
Might look at the Racetronix/Delphi 37 lbs as well.
Old 02-06-2008, 06:47 PM
355z28's Avatar
ford also makes a 35lb injector, u believe they're brown tops.
Old 02-06-2008, 07:18 PM
BADHAWK51's Avatar
Lucus 42#s here.
Quick Reply: Which injectors for my 383
