View Poll Results: What do you use for a replacement pump?
OEM style
10
16.13%
Walbro
49
79.03%
TRE
3
4.84%
Voters: 62. You may not vote on this poll
What are you guys using for fuel pumps??
Just wondering what you guys are using for fuel pumps? stock replacements or walbros and what size.
Recently I put two pumps in a buddies TPI car he ordered a holley and it went bad (it said walbro right on the pump) then he ordered a bbk and it was made by walbro also..
Basically Im in need of a fuel pump because i have volume but low pressure and dont know what one to run, a link or a pm of what is a good ideal pump for me would be greatly appreciated
Austin
Austin
Ok i found the racetronix kit, it is a walbro pump http://www.thunderracing.com/catalog...vid=4&pcid=165
Since my setups not extreme should i even get the wiring harness??
Yes the Racetronix kit uses a Walbro pump BUT it is not the kit every one buys when you say Walbro pump. The Racetronix kit is COMPLETE and makes the job at hand easy. The Walbro kit is a hack at best IMHO.
I have installed Dozens of both as well as some of the others
