cam break-in procedure
The LT1 has a roller cam, roller cams do not have a break in requirement. Hydraulic cams require RPMs to be held ~>2500 for the first ~20 minutes, and not held at a steady RPM to help the cam stay oiled and prevent it from wearing a lobe.
Now after working on your motor and putting lube on lifters, it is a wise investment to change oil. This will get the cam lube in the filter and in the trash. I would probably do it lower mileage maybe 50 miles. What you want is the 'trash' and lube to get in oil and out of motor.
Hope that answers your question.
