Dtc-13
Dtc-13
Ok, so I have a DTC13 on my newly aquired 93Z28 M6... My question is, does this usually just mean simply a new oxygen sensor is needed, or could it mean something else? Thanks.
http://chevythunder.com/199295_lt1_t....htm#Code%2013
Code 13- Oxygen Sensor circuit. Check for wiring and connections problems from the O2 sensor back to the ecm. If no problem is found, replace sensor.
