383 cam with ported heads
Old Jun 25, 2008 | 09:59 PM
th3brandon's Avatar
Default Good cam for 383 with stock ported heads
whats the best cam to run on a 383 with stock ported heads....i want something with good low and mid range power...i looked at comp cams and saw all the cams that they have to offer just now sure on which one would be good for my setup...which the rest of my mods r in my sig...i do alot of drag racing and need something to be able to get off the line good and stay with it thoughout... just need some help from u guys that have been here or there before
Old Jun 25, 2008 | 11:16 PM
th3brandon's Avatar
i found 2 cams that seem to be all right
1.comp cam (xfi) 218/224 .570/.565 113lsa with 1.6rr
2.comp cam(305) 220/230 .510/.510 114lsa with 1.5rr
tell me what u guys think
Old Jun 25, 2008 | 11:23 PM
1badzee's Avatar
Go with a custom grind, in my opinion. Especially with ported heads (because not every port job is dead on with the previous or next). So get em flowed and get a cam made for those specs. That way you get as much power possible
Old Jun 25, 2008 | 11:27 PM
th3brandon's Avatar
yea that crossed my mind but iam looking for something more out of the book type deal (little cheaper)
Old Jun 25, 2008 | 11:29 PM
1badzee's Avatar
In that case I wouldn't know what to recommend to you.. cc503s an d GM847s are pretty popular on 350's but not sure with 383s..
Old Jun 25, 2008 | 11:58 PM
StealthFormula's Avatar
The cams you listed would be pretty tiny on a 383, would work decently well on a 350 tho.
Old Jun 26, 2008 | 12:12 AM
1badzee's Avatar
Fixed. Thanks =P
Old Jun 26, 2008 | 12:13 AM
texas94z's Avatar
agreed. do you have any flow numbers for the heads? those numbers can give you a good indication on what cam will perform best for your 383. but give bret bauer a call and get a custom grind.
Old Jun 26, 2008 | 09:33 AM
th3brandon's Avatar
i dont have the flow numbers for heads because they were done last year...their are not any cams you guys would reccomand that i could just buy...or maybe u guys know of just a good all around cam for this setup...put it this way i need the best cam for my setup that is not custom grind
Old Jun 26, 2008 | 12:57 PM
Formula383's Avatar
I've got a CC306 in my 383 with stock ported heads. Definitely a mild cam for a 383 but it makes for a great street car.
Old Jun 26, 2008 | 01:48 PM
BALLSS's Avatar
Default Xfi
I run the XFI (466) grind you listed in my 383. Smooth idle, smog is no problem, great TQ and pulls hard to over 6000 RPM's.
I know it is not a "big" cam but is what I was looking for in a "off the shelf" cam. The 467 is "bigger" if that is what you want but my sense is you will give up some low end TQ vs the 466.
You WILL need to run bee hive springs with this cam (918's)
Old Jun 26, 2008 | 01:53 PM
LT1MAN's Avatar
i have the cc306 in my 383 with stock (barely ported) heads and it does the damn job, my heads dont flow well enough to let me judge how it would do up top but down low it gets the car moving, fast, the 4.11 gears help too.
Old Jun 26, 2008 | 05:55 PM
For the record a cam such as the cc306 in a 383 would act similar to say the cc503 in a 350. The more the cubes the less you have to rev it so a 350 cubic inch motor with say the cc306 may have to rev it out to like 6700 where if it were in a 383 it would be more like about 6400. If I was building a 383 with and was limiting myself to an off the shelf camshaft then the cc306 and gm847 would be among the top of my list.
Old Jun 26, 2008 | 08:34 PM
th3brandon's Avatar
i was thinking about both of those cams....also Ai has one thats on top on my last as well its the 226/234 .540/.575....i talk to the guy and it seems to a pretty nasty cam for the street and thats what iam looking more for lets just say street racing lol red light to red light something very good off the line and strong mid range
Old Jun 26, 2008 | 09:12 PM
highflyin's Avatar
CC306 F T W. Did you pull your car apart yet to see whats usable and whats not usable yet? If your block is screwed then i know where there are some lt1 motors out of caprices at that could probally be scored cheap.
Old Jun 26, 2008 | 09:13 PM
If your willing to dish out $400 for that cam then I would go custom because a custom grind will cost you either the same or a tad less depending on who you get it from whether it be Ai or Bret Bauer or Cam Motions etc.
Old Jun 27, 2008 | 11:53 AM
th3brandon's Avatar
yea thats true to i think its going to be like stated above the cc306 or the gm847 iam going to do a little more reseach and see what i can find thanks for all the help
