a/c compressor removal
I am in the process of removing the a/c and cannot get the compressor out. the 3 mounting bolts are out as well as the bolt in the back that holds the hoses on. When I try and pull it out through the bottom, it is restricted by the power steering pump lines and the fans. Is it able to be pulled from the top? Any other ideas?
Yea, I just took mine out without removing any of the PS Lines or Fans, you just have to twist it a certain way and muscle it out. It's a pain but it will drop out.
Good Luck
Good Luck
You gotta twist it, yell at it, swear, pound a beer, cut yourself, pound another beer, then twist it more, but it will come out. I know when I did my car delete I just did the front 3 bolts and yanked, it came out with some gentle "persuasion"
Car delete? is this a new mod i dont know about?
