no spark, no fuel
Old 09-25-2008, 02:17 PM
camzaro28's Avatar
Default no spark, no fuel
What could be wrong with my car?
I have over 40 psi at the schrader valve.
There is no spark anywhere in the ignition system, mind you with a noid light on the injector clip while cranking there is a weak/faint flash. So it is atleast getting the signal, just a very wek one.
Then talking fuel, while cranking with the fuel rail lifted, the injectors have a tiny mist coming from them.
I have replaced.......
new GM opti
new GM coil
new advanced auto ICM
I also went to GM and bought and returned the opti harness due to it not fixing it.
What else can I do?
FWIW, I pulled the opti off with everything connected and with the KOEO if I spun it you could hear the injectors spraying and the noid light would flash full bore.
What is that telling me?
Old 09-25-2008, 03:01 PM
fergymoto's Avatar
Run through this it should get you figured out.
http://www.mainstreamtopics.com/foru...p?showtopic=78
Old 09-25-2008, 05:14 PM
camzaro28's Avatar
Everything came back fine except for pin # b14 on the PCM there is no voltage there. So I jumped and ran my own wire from the PCM in place of that wire and nothing happened.
Quick Reply: no spark, no fuel
