Adjustable Torque arm and Control arms needed ?
I have a 94Z that i plan on keeping the stock height. i might get new springs and shocks at a later time but i dont ever plan on lowering it. do i really need adjustable control arms or a torque arm ? is it really worth the extra mula for that ? would i need them to be adjustable if i were to get a 9" or an S60 one day to get the pinion angle right ? i wanna get them soon but need to know if its really necessary or not. Thanks!
Yes to adjustable everything...If you want the car to work as it should at the track having a fully adjustable suspension is key. You'd be amazed at how out of square the rears on these cars are from the factory. Having adjustable lcas help with centering the tire in the wheel well and for squaring the rear under the car. Imho if you are going to get new lcas its foolish not to go with the adjustables...
--Alan
--Alan
Well I guess that the fact that my old Camaro ran a best 1.26 sixty foot on 9" tires this year was a fluke. Same goes for my current Firebird running low 1.3's. I could probably give you a list of 100 F-Bodies that sixty foot in the 1.3's that are not allowed to run adjustable lower control arms.
Don't believe everything that you read in GM High Tech Performance. Lot's of people out there will sell you stuff that you just don't need.
FWIW I was running low 1.4 sixty foot times with the stock torque arm.
Good Luck,
Daren
Good Luck,
Daren
I say just buy the non adjustable unless your super serious about getting every last bit of power to the ground and like dicking around with it alot, wich is kinda a pain in the ***.
I took off my tunnel mount adj TA and went with a Standard lenght NON Adj Ta and couldnt be happier. Couldnt stand it for a DD
Thanks for all the input with this. ill probably get the non adjustable chromemoly control arms and an ajustable torque arm. its my street/dd car and will see the track once in a blue moon. i dont think i need to spend much more money on that when i can put it towards a cam swap
Good Luck,
Daren
Good Luck,
Daren
--Alan
If you really believe that your car is out of square, what did you measure to figure it out? How do you know that the wheel opennings are in the right place? Did you check the brackets on your rear housing? Who says that the front end of the car is any better?
I'm not at all bent out of shape, but adjustable rear control arms just aren't needed to run even a 1.2 sixty foot time. I can see the bearings helping, but I've only ever used poly bushings in my cars.
--Alan
