car overheated what happened?
Old 10-04-2008, 12:24 PM
Z28madmike's Avatar
Default car overheated what happened?
i was drivin around last nite then all the sudden the cars temp spiked and i lost power steering and the car overheated any ideas what happened? and what should i be checking damage wise?
Old 10-04-2008, 12:27 PM
Elliott's94Z's Avatar
Water pump go out??
Old 10-04-2008, 12:31 PM
Z28madmike's Avatar
its possible i just had a bunch of work and resealing and the mechanic had the waterpump off 3 times and the thermastat but last night i drove it for 30miles possibly overhheating. what are the odds of heat soak to the heads? or warping them?
Old 10-04-2008, 12:41 PM
Not sure...but my guess is something went wrong with the pump. Im sure someone will chime in and give some more sugg.
Old 10-04-2008, 12:54 PM
Badazz 97 TA's Avatar
did he bleed the air out of the coolant correctly?
Old 10-04-2008, 12:57 PM
Z28madmike's Avatar
not sure but i rechecked anyways considering the car was running 10 to 15 deg hotter since the work was done
Old 10-04-2008, 04:58 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Check to see if the water pump is leaking out of the weep hole. It's there to show you if the water pump bearings are failing. You could also burp the coolant system to try and check for air pockets. The best thing you could do is start doing all of the work yourself so you don't have to worry about other people ******* up your stuff and save a lot of money.
Quick Reply: car overheated what happened?
