m6 swap problem with pics
Old 10-26-2008, 05:10 PM
therobman's Avatar
Default m6 swap problem with pics
i installed my peadals and the clutch pedal is further up then my brake pedal by a decent amount and i connected the rod to the brake and the clutch i dont have anthing else hooked up the tranny is sitting in my garage is this normal or what. sorry for the crappy pics
Old 10-26-2008, 05:37 PM
the_merv's Avatar
Looks normal to me, is the Clutch Petal hitting the stop on the side of it? Does it go all the way to the Floor when you push it in..?
Here are a couple pics of my swap for refrence..
Old 10-26-2008, 05:42 PM
Black02SLPSS's Avatar
Mine sits farther forward than the brake pedal does. I think its normal. I did my a4-m6 swap earlier this year.
Old 10-26-2008, 05:49 PM
therobman's Avatar
the pedal goes all the way to the floor when the rods disconnected because i cant do it with the rod on cause i dont have the tranny on and the pedal hits the stop and i have to push it down the slightest little bit to slide on the rod
Old 10-26-2008, 06:45 PM
the_merv's Avatar
I meant with the Master Cyl connected, if it still goes to the floor or pretty much all the way down, you are good.
Old 10-26-2008, 07:55 PM
therobman's Avatar
yea im almost positive it will i just wanna be sure im putting the trans in on wed so we will see
