Aluminum Flywheel + 100 shot?
Typically an aluminum flywheel will let the engine rev quicker but takes a little of the low end bite out of the car . I would not see using a flywheel like that with nitrous as being a bad thing at the track .
Closed ex-Sponsor Account
Flywheel
I am pretty sure that an aluminum flywheel would be fine for your aplication, however I have seen some ring gears come off and flywheels warp etc. This is not a common problem with aluminum, but it is a problem. If you are concerned about this, we offer forged steel flywheels that are light weight and will serve the same purpose and are SFI certified.
