cant change after 5K Rpm
hey everybody
i have 2002 TA and i just did rebuild for the engine and i changed my clutch(spec Stage3+)and new slave and master even new gear montings
today i finished the breaking and i tried the car but unfortunetly i cant change when there is pressure on the car i mean when the rpm goes to 5000 Pluse i wont be able this change the gears and it happends in 2 3 4 5
can you help me to find the problem
hey everybody
Well, sounds like a disengagement issue. No mention of a shim install...did you install one? Pretty sure Spec clutches call for one.
Also, it COULD be teh stock MC not pushing enough fluid (major problem) and not allowing clutch to disengae at higher RPMs. There is a Spec tech on this site, and I am sure he will be chimig in quickly
Give us some more details,like who bled the system,and how?
hi thanks for reply
im not living in usa
im living in dubai and i did it locally here
i think spec left some shim on the clutch kit and i install it already
1 Post
Sounds like aggressive shifting and theres nothing wrong with that. It happens to alot of us. . . .
The drill-mod might help, good quality clutch parts might help. Look at all the threads here over the past 6 months where people complain about clutch and those recommendations. You'll notice if you wait or let off of the gas after a few seconds the shift can happen. Good luck.
