LTx Adjustable Master - Are the LS1's ones the same?
So I'm looking for an LTx adjustable master cylinder, but the only ones I can find say 98-02. But then I was able to find one that said 93-02, but I thought they were different.
I know that Ram makes one, for a decent price but I seriously can't find a part number anywhere.
LS1TECH Sponsor
The master itself is the same, but the line is different due to different styles of slave cylinders. Rams adjustable master is a modified stocker...theres probably a sticky here that tells you how to make your own master adjustable. IMO, doing this really doesn't offer much adjustment however...it only allows you to adjust the freeplay at the top of the pedal which should already be minimal.
We sell an adjustable master that comes with the appropriate line. http://www.tick-performance.com/tick...aulics/#master
If you order ours, just specify that you have an LT1 and we'll send the appropriate line to make it work.
