Torque spec for pressure plate bolts on Spec AL flywheel?
I've got a Spec 3 for my LS1. I know the factory torque spec is 52 ft-lbs for pressure plate bolts, but I wanted to verify that it is the same for the Spec 3 when using the aluminum flywheel. I'd hate to strip it out.
Thanks,
-ch
Thanks,
-ch
Our single-disc assemblies are intended to use the OE torque specs for both the pressure-plate to flywheel and the flywheel to the crank. Let me know if you have any further questions. Thanks,
