Which transmission
Which transmission
I am currently going through the build process of a 383 stroker / Single 78 mm turbo. I have an 02 ss M6 with a stage 3 monster clutch (with maybe 5K miles on the clutch) hardened gears and aftermarket syncros, 9" rear, and 3 1/2" steel drive shaft. Should the tranny/clutch hold? I'm expecting hp numbers in the mid to high 700 range. If not, any suggestions would be appreciated. I am opposed to switching to an automatic.
tranzilla if you are going big and bad
http://www.rsgear.com/index.asp
Also
d&d's magnum
http://www.ddperformance.com/magnum.html
Also
d&d's magnum
