lt1 t-56 to run with 5.3
Old 12-21-2009, 08:13 PM
duneordie's Avatar
Default lt1 t-56 to run with 5.3
What is involved with making my lt1 era tranny fit the ls blocks, i will more than likely go with a 5.3, I have everything from the flywheel back from a 95 SS... thanks in advance. I have searched here and found it the other way around ls to lt.
Old 12-21-2009, 08:49 PM
jay7199's Avatar
belhousing... and imput shaft? i think..
Old 12-21-2009, 09:13 PM
bww3588's Avatar
stick a 6.0 crank in it. the 5.3/5.7/some of the 4.8 cranks are shorter than the old SBC crank, but the 6.0 LQ4 cranks are the same length.
Old 12-21-2009, 11:07 PM
duneordie's Avatar
so then would it just be easier to go with a 6.0, will any 6.0 fit correctly?
Old 12-30-2009, 09:18 AM
custom 68's Avatar
You might check this I thought that was only some of the early ones. I am not sure on this though.
Dave
