Bleeding clutch fluid?
Old 01-18-2010, 06:15 PM
airattack111's Avatar
Default Bleeding clutch fluid?
I have tried sucking the air out from the reservoir, but it didn't to much to cure the spongy clutch pedal on my car.
Is there a how-to guide on gravity bleeding the clutch fluid? From what I understand there is a screw underneath the car (not sure where?), and you unscrew it a bit to let the fluid flow out and continuously fill the reservoir not letting it get low.
Is this correct? Will this get all the air out? Where is the screw and how do I get to it?
Thanks.
Old 01-19-2010, 01:35 AM
KTK Z28's Avatar
Gravity bleeding is probably not going to get all the air out. Actually i am almost certain that is not going to work. You will likely have to have a buddy help you bleed the clutch the traditional way.
The bleeder screw is in a really crappy place. It is on the driver side of the transmission towards the top. You cannot see it from under the car without a mirror. It is right next to the braided line that i BELIEVE goes to the slave (i might be wrong here). Again use a mirror and you should see it. I believe it's an 11mm.
Old 01-19-2010, 07:56 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I have always Gravity Bled the clutch. Works everytime.
Old 01-19-2010, 08:10 AM
disc0monkey's Avatar
for me i had air in my master and gravity and the tradition two person way didn't work. i stuck the mityvac down the reservoir hole and i got my pedal back right away. i gravity flush the system though.
Quick Reply: Bleeding clutch fluid?
