having clutch issues
I recently had a friend of mine put a LS7 clutch and flywheel in my car. Before the clutch come out you could barely touch the pedal and it would fall a little and hit its pressure point, but not all the time. The pedal only had a littl travel for engaging clutch. Clutch was replaced and shifted fine and pedal felt fine for a couple of days. No hossing or dumping the clutch. the pedal is starting to lose its hold again. I can pump it back up but after driving it loses pressure. Any idea.
What got changed
Clutch/flywheel
Clutch Slave
pilot brn
release brn.
What got changed
Clutch/flywheel
Clutch Slave
pilot brn
release brn.
