So would the aluminum one be better?or would it matter?
If the slave is close to your headers/exhaust, it should help. Otherwise I'm not sure it matters. The aluminum version also has a bleeder screw which may help. Typically you can bleed the LT1 hyd just by pumping the slave rod though..
