1994 Camaro V-6 5 speed to LQ4 M6 Tranny cross question
As the title states i'm swapping a 6.0 LQ4 with a 2000 Camaro T-56 into my 1994 Camaro 3.4 5 speed.
I have the engine installed and the transmission bolted up however the stock 94 3.4 5 speed Transmission cross member doesn't bolt up any longer. It's off by about 2" towards the back of the vehicle.
The transmission came with a M6 cross member which also does not fit.
Does anyone know what cross member I need to make this sucker bolt up? Or where I can get one that will do the trick? Any useful input is always appreciated. Thank You in advance.
Yes the tranny came with the ls1 crossmember. Your answer was my guess but I wanted to be sure before I went ahead and bought one. Do you know who makes one aftermarket? Some reason i'm having difficulties finding one.
We do offer a torque arm relocation bracket that would work great for your application especially being you already have the stock components removed.
There are many benefits to running a relocation bracket-
- Takes the load from the torque arm and removes it from the tail shaft of the transmission removing the chance of damage to the transmission.
- Our relocation bracket has multiple mounting positions for the torque arm which will allow you to fine tune the suspension to match your needs.
- Our relocation bracket is compatible with all after market torque arms as well as your factory stamped steel torque arm.
