Fluid level question
Old 03-03-2010, 09:35 AM
Stang-Slayer's Avatar
Default Fluid level question
heres another dumb question for you guys
I have new fluid in my trans....synchro-mesh
But I am not sure how much is in it due to pulling the trans and adding some (Still new fluid the entire time, never ran when put in car)
Well when I put it in the car this last time I just had pulled the fill plug on the side and seen fluid was coming out of the hole.....That should be the right level right?
Old 03-03-2010, 10:41 AM
Kleeborp the Moderator™
MeentSS02's Avatar
You are correct...the fill plug on the T-56 is on the side for a good reason - idiot proof way to fill the transmission to the proper level, provided the car is level when you fill it. Should be about 4 quarts regardless.
