Whine/Humm upon clutch disengagement?
Hey all,
Last summer the car got a Monster Stg 3 clutch and Chromoly flywheel. About a month after the install I started to notice a slight hum/whine when I released the clutch, it would start light and get more pronounced as the load was transferred. It isn't a rear end whine, any thoughts? A bearing maybe? The car really hasn't been beaten on.... yet....and has only about 13k miles on it....
Everything else seems great clutch holds extremely well, engages solidly etc etc....probably just a bearing issue but I am here for ideas!
Thanks,
Jeff
Thanks,
Jeff
I've got the same issue. Talked about it in another thread about a noisy squealing when clutch is engaging. I've got 10k on mine now but its made the noise for a while and got a little louder recently. Didnt realy get a true explanation except could be weather(i dont think so), clutch could be done, bearing like ^ said, or possible scarring/dirty clutch/flywheel.
I see in your sig that you have a MWC 9", how do you like it? I will be doing mine here in a couple of months.
If you have a squawking noise when you are engaging the clutch this means the disc is glazed. You need to take the car to the track (or a deserted road) and launch it aggressively a few times to "knock" off the glaze. After you do this change your driving habits and slip the clutch less when you are taking off during normal driving.
If this doesn't describe your issue call us, we can't help you out if you don't contact us.
Jeff
