Tick Master, What brake fluid ?
mcleod master. the rubber seals were gummy and fell apart inside the cylinder but in hind sight, it might have been the synthetic brake fluid I used at one point.
And DOT 5 is a silicon based brake fluid where as DOT 3,4 and 5.1 is a Polyglycol ether based fluid. So thats why if you put a silicon based fluid in a system designed for the polyglycol ether based fluids you will have a premature failure of the seals and what not.
