HELP!! Broken Pieces=SUCK!!!
Old 04-13-2010, 12:01 PM
flatbird's Avatar
Default HELP!! Broken Pieces=SUCK!!!
On the highway my car quit allowing me to put it into gear and its been making a slight rattling sound for at least 2 months. So I pull it off, park it at a gas station and then get it towed home.
I then put it on some jack stands, took off the slave cylinder and this is what fell out. Can someone identify these pieces? HELP!!!
Thanks,
Cody
Old 04-13-2010, 01:04 PM
85MikeTPI's Avatar
An LT1 T56? or an LS1-T56? From the slave description I'd guess LT1 but guessing sux..
Looks like you have a pilot bearing, what looks like an LS1 slave bolt, and case parts I can't ID with out better pics..
Can you take pics of the front of the T56 where the input shaft is, the back of the crank where the pilot sits, and those pieces at different angles?
Old 04-13-2010, 02:03 PM
flatbird's Avatar
Here are a few more photos. Hopefully this will help.
Old 04-13-2010, 02:55 PM
flatbird's Avatar
Anyone?
Old 04-13-2010, 03:14 PM
flatbird's Avatar
To be honest I'm not exactly sure how the clutch fork is put together. I'm thinking this might be a bearing that goes in between the two pieces that make up the fork. I'm just hoping that my tranny is'nt shot.
Old 04-13-2010, 03:30 PM
85MikeTPI's Avatar
LT1???
There's no roller bearings like that except for the pilot, and your's is too small to be a pilot. Could be a Pressure-plate piece or a starter piece, but nothing comes to mind from the pictures.
Old 04-13-2010, 03:45 PM
flatbird's Avatar
Sorry dude...lt1...
Old 04-13-2010, 03:51 PM
flatbird's Avatar
Is the clutch fork one solid piece or two seperate pieces?
Old 04-13-2010, 04:48 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
Like everyone else.. It looks like the pilot bearing. But its scary if it broken out of the back of the block.
Old 04-13-2010, 04:50 PM
Justins00ss's Avatar
looks like part of the piolet bearing, but not too sure about the other pieces
Old 04-13-2010, 05:19 PM
85MikeTPI's Avatar
Sorry dude...lt1...
OK..
Pretty sure the chunks and the bearing are from your starter.
The bolt may have come from the clutch (Do you have an aftermarket clutch?) or somewhere, and it actually grenaded the starter nose..
The LT1 clutch fork is one piece, and the pivot is solid.
Old 04-13-2010, 06:06 PM
Redneck Z's Avatar
It's the pilot bearing and the 'socket'(for lack of a better word) that it taps into behind the crankshaft.
Old 04-13-2010, 07:20 PM
dave70's Avatar
looks to small to be the pilot i have my old one right here looking at it . Like mike said could be the bearing on the nose of the starter for the shaft the bendex gear or whatever it's called. just pull the starter and have a look see
Old 04-13-2010, 07:22 PM
dave70's Avatar
Can you tell if the chunks are cast aluminum?
Old 04-13-2010, 07:36 PM
fergymoto's Avatar
That is definitely the nose of the starter and the bearing that goes in it. It is not the pilot bearing. The bolt loots like a rear seal housing bolt.
Old 04-13-2010, 09:16 PM
ArcticMissile's Avatar
It's the pilot bearing and the nose cone off the starter. The bolt is from the clutch. Looks like you torched your clutch which in the pilot bearing took a ****. The only true way to tell is to drop the trans bud.
Old 04-14-2010, 09:47 AM
flatbird's Avatar
Yeah, I live in an apartment so I have to haul the damn thing to my parents house and get it on some stands...GAY...at least I have a second mode of transportation in the meantime...any tips on transmission removal?
Old 04-14-2010, 11:24 AM
fergymoto's Avatar
Fact: It is not the pilot bearing!!!
Fact: The bolt is not from the clutch!
Old 04-14-2010, 11:28 AM
beedo's Avatar
Fact: One pic its the nose of the starter! LOl
Pull the starter and try and figure out what broke it to shreds!
Old 04-14-2010, 01:28 PM
flatbird's Avatar
FACT: My car is incapacitated
FACT: I now must resort to driving a mustang
Appreciate the help...I'll get back with you when I drop the tranny...
Quick Reply: HELP!! Broken Pieces=SUCK!!!
