I cant get any clutch pedal pressure!!!!!
Old 04-27-2010, 11:09 PM
mylittlez06's Avatar
Angry I cant get any clutch pedal pressure!!!!!
I put a new slave, master and tick shift speed bleeder in my 2000 SS, I bench bled the master and I still cant get anywhere with this thing, im getting fluid past the speed bleeder but not a whole lot, what am I doin wrong here...is there a certain way to bleed the speed bleeder......I need help ASAP....thanks
Old 04-27-2010, 11:59 PM
lazyhomie's Avatar
Well I dont have any experience with a speed bleeder but when I did my master I had to pump the pedal plenty plenty plenty of times wiithout ever opening the bleeder in order for the pedal to get some pressure on it. You have to pump it plent of times to get fluid moving thru the parts and start getting air into the lines and out the parts that way air escapes when you open the bleeder. Just pump it plenty of times before trying to bleed it and it will get some pressure.
Quick Reply: I cant get any clutch pedal pressure!!!!!
