Spline count on TR-6060
The following users liked this post:
Homer_Simpson (10-08-2023)
The TR6060 going in what car? if its an 98-02 F-body it will not work.
You need the T56 tailshaft housing because the TR6060 is 2-3" shorter than the T56 therefore you can not shift into 1,3,5 in a sence, you are too close/ hitting the center console. Also the factory TR6060 has a flange out put shaft, you need a yoke.
RPM makes a level 5 kit with all the mods to install in a 98-02 F-body for around 5k i believe.
I guess I'll find out tomorrow when I put it all together.
