61 tooth 5th gear?
61 tooth 5th gear?
Does anyone have a link or a part number for a 5th drive gear with 61 teeth? It came out of an 05 -08 vette T56, and my supplier is having trouble locating it(also having a problem with being pleasant, but that's another story.
Here's a thread for reference:
https://ls1tech.com/forums/manual-tr...gear-swap.html
If it's definitely from a vette, then it would almost certainly have to be a Z51 (MZ6) optioned unit. Since it's a GM-only unit, you most likely have to get it from a GM dealer. If it's from an '08, then it's not a T56, but a T6060.
Well then I know its the T56 because there is not even any ports on the midplate for a line. I'll call around and see if I can get any info on where to get the gear I need.
Is this trans out of your Vette? The midplate shows where the front mounted fluid pump would bolt to. Another easy way to tell if you have a pump or not is to look at the front of the cluster shaft, it should have a "slot" cut into the front where it drives the pump.
