Monster flywheel pressure plate bolt size??
For those running a monster clutch flywheel do you reuse the original pp bolts or are they a different size? I had a Ram flywheel on that needed a different size bolt so now I need some clarification as to what to order. Thanks
SSmiley
SSmiley
I suggest ordering some arp pressure plate bolts and flywheel bolts to go with it just for added insurance and use threadlocker for peace of mind. Thats what i did for mine.
Many thanks, will be ordering arp's for both the flywheel and the pp. Also a new timing chain and oil pump to go with the ms4 install. Gotta get this **** done, Carlisle is looming closer by the day lol.
Not sure what difference it would make using arp bolts, they are just as strong as stock and should be stronger. I can look and see what the difference is by eye since i got the transmission out. Only if they are longer or some difference in the bolt head.
