Spec 3+ / fidenza FW = vibration at 1st gear
Old 05-20-2010, 02:08 PM
Cold Zero's Avatar
Default Spec 3+ / fidenza FW = vibration at 1st gear
Hi
I installed spec 3+ / fidenza FW and there is some vibration on 1st gear is it normal or bad installing ?
The rest gears shift very smooth
I'm only doing 20 miles on it until now
Old 05-20-2010, 04:00 PM
Red99TA's Avatar
Is it when you're taking off from a stop or just anytime you're in 1st gear with the clutch out?
Originally Posted by Cold Zero
Hi
Old 05-20-2010, 08:52 PM
Cold Zero's Avatar
When take off from stop only
Old 05-21-2010, 06:19 AM
Red99TA's Avatar
Sounds like its just clutch chatter. I would say that's pretty common on break-in of a new clutch. The 3+ is a full face so I wouldn't think it would chatter but then again my twin disc is also full face and it chattered a little bit for the first 30 or so miles. I would think that if it is chatter that it will go away completely as you get some more break-in miles done.
Old 05-24-2010, 02:21 PM
SPEC-01's Avatar
A little chatter is common when leaving from a stopped position in first or reverse with little mileage on the clutch. Complete the break-in process and it should smooth out. Feel free to contact me with any questions you may have. Thanks!
Old 05-25-2010, 06:37 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Having a light flywheel doesn't help the situation either. In time it will get better, and you'll get used to driving it again. It just takes time and miles.
Old 06-06-2010, 02:52 PM
Cold Zero's Avatar
thanks to you all guys
After 250 miles the chatter goes and now it runs smoothly
Quick Reply: Spec 3+ / fidenza FW = vibration at 1st gear
