How do I change my throwout bearing.
I have a new centerforce throwout bearing but I can't figure out how to remove it from the throwout bearing housing. Is there a clip I'm not seeing or is it pressed in. Me new bearing also looks a little different then the old one. The surface where the shifter fork rides is shorter.
Centerforce P/N N1716 for a 95 Z28
thanks
thanks
To remove the original bearing you need to compress it, pushing it down, and turn it to the left. It will click and come right off. Then you press the new one on and turn it to the right. It can be a little difficult to to do but don't over-think it!
No that did not work. I already have the bearing off the PP. Maybe I got the wrong one.
Hear is the bearing I'm taling about.
http://www.summitracing.com/parts/CTF-N1716/
On an LT1, there is a spring that goes about 3/4 of the way around the bearing. Just pop that spring out, then the bearing will come right off the pressure plate fingers. $268 for just the bearing is rediculous...You can buy a complete new clutch kit with TOB for $199 from Autozone.
Sorry man...I was thinking LS1 not LT1. There is a clip-ring on the bottom of the bearing, pull the clip-ring and the bearing will slide right out. As for the cost of the bearing, you normally can;t buy these seperately so the dealer was likely billing you for a new plate too!
Hear in Canada the cheapest clutch I can buy is a Luc for $450. I dont need a clutch, and a stock clutch is not going to do me any good.
I'm looking into beefing up my tranny so I'll deal with the bearing then.
Spec 01. No that was just the price for the throwout bearing. Just for the heck of it I asked how much for the complete clutch and the dealer said $1300. We get robbed up hear in Canada for auto parts.
