Can the stock LT1 flywheel be zero balanced and can I use aftermarket pp/disc?
Looking to save some coin after the engine rebuild and was wondering if possible to use the stock flywheel after the engine gets balanced. I noticed the counterweight on the back of the stock flywheel and wanted to know if it could be shaved off.
Also, I'm going to be spinning the engine close to 7k so is there a disc/pressure plate I can use with the stock flywheel? Thanx
