oops oil pouring out of tail housing
Could use a bit of help guys....I'm installing a Ls3/T56 into a BMW (thread in conversion section - Z3 install etc). The engine has been in and out loads of times with no problem. Tonight I pulled the engine out and whilst it was tail end down there was oil pouring out of the rear seal where the driveshaft goes in. Lost maybe a pint of oil until I got the engine level. Its not done that before but recently I fitted the driveshaft. The driveshaft is difficult to remove so I dropped the back of the tranny and slid the engine forward off the yoke.
Any idea what I have done and what to do about it? Is it just a matter of fitting a new rear seal? Maybe is got knackered as the joke fell out. I want to get the engine back in tomorrow and need to know if I can change the seal in situ. Thanks in advance guys...
Andrew
Thanks for that Andrew. Why didnt it leak before then? I have had it on the hoist at about 10 degrees down several times with no oil coming out. Its a new T-56. Its only happened now after a yoke has been fitted.
Maybe when you had it at 10* down on the hoist, the transmission fluid level was low enough that it didn't come out. When I pulled the T56 out of my old Camaro recently, I drained as much fluid as I could before having it slant back but once the angle was steep enough it still dripped like a quart more. I wouldn't worry, just make sure to fill it back up once it's back in.
Thanks for that. I think Im just plain stupid. When I fitted the engine previously the transit cap was fitted onto the splines. That must keep the oil in. Anyways happy days panic over.
