New LS9R clutch for F-body/GTO
We are now taking pre-orders for the LS9R clutch kit for F-body/GTO. The F-body required more custom parts to make it work so that is the reason it is priced higher than the Corvette kit. $1949.99
http://store.katechengines.com/ls9r-...ygto-p255.aspx
I'll announce a firmer delivery date the week of 1/24/11, but right now estimating about late February or early March. You can get your pre-orders in now to reserve your parts. Your credit card will be authorized but we will not charge until it ships.
-For 1998-2002 Camaro/Firebird V8 & 2004-2006 GTO
-Twin disk clutch
-Enhanced ZR1 clutch disks and pressure plate
-Aluminum flywheel with 6 bolt pattern for standard LS engines
-Includes Katech custom slave cylinder
-Includes pressure plate bolts
-Includes bellhousing spacer (less than .5", requires no modifications)
-8lbs lighter than the stock Z06 clutch/flywheel assembly
-Flywheel weighs 12.0lbs.
-Drives like a stock ZR1 - stock pedal feel
-960+ ft-lbs torque capacity (20% over LS9X clutch)
-No neutral noise or chattering
-All of the benefits of a twin disk clutch and none of the trade-offs
-Twin disk clutch
