Clutch or trans?
...really?
provide some information concerning/describing what is actually not functioning properly and then maybe someone will have a useful response. at this point there is no way anyone can help you.
had to use the car's starter to get moving at every stop light and rev match every shift
well not entirely true, I drove this clutch for 2 miles after the friction material sheared off and lodged itself into the pressure plate, rendering it impossible to disengage:
reverse works all gears work perfect exept for 1st but the Clutch does have 170000 miles on it. also this happened to after the throttle got stuck on the wot position and i had to launch the car at wot out off the freeway 2-3 launches to get completely out the way of getting crashed
