t56 ls1 input shaft dimensions
Old 04-17-2011, 03:02 PM
mikebo69's Avatar
Default t56 ls1 input shaft dimensions
Does anyone have a ls1 input shaft laying around where they can get the following dimensions for me?
1) gearface to end of shaft
2) gearface to start of splines
3) gearface to end of splines
Thanks
Old 04-17-2011, 03:10 PM
gcallahan's Avatar
Default input shaft dimensions
1) 8 5/8
2) 5 1/4
3) 7 1/2
Old 04-18-2011, 02:08 PM
mikebo69's Avatar
Thanks! I have a m29 lt1 t56 that i want to convert to ls1 trans. The problem is locating a 2.97 gear ls1 input shaft. I thought of using the 1386-585-007 input shaft and making a spacer adapter between the trans and bellhousing. also need to know the recess of the slave mount from the top side of the midplate. It looks like the input shaft is 3/4 inch longer.
Old 04-18-2011, 02:45 PM
85MikeTPI's Avatar
Sell the M29 and get an M12, or at least get Jason@TDP to cut/weld the aftermarket input shaft you're looking at. You'll be way ahead of the game in the long run. (You can convert over to a LS1 front plate, but you'll need a bunch of shims on the countershaft since the '93 bearing race pockets were set ~0.060" higher than all the other GM T56s.) The '93s also had smaller inputshaft/countershaft mesh gears and thus got a smaller power rating than a M12 would have.
Old 04-19-2011, 08:20 PM
gcallahan's Avatar
I also have a LT1 t56 from a 97. Ive got the LS1 input, mid-plate and bell housing to convert it.
Old 10-14-2011, 04:17 PM
Slamedcam's Avatar
Default Ls1 input and mid plate for convertion
Hey man do u still have all that convert ion stuff I would really like to buy it lmk asap or call me at 865-363-3758 thanks TJ
Quick Reply: t56 ls1 input shaft dimensions
