vertical shifter movement under heavier accel
When I am under harder then normal acceleration, lets say 50%+ throttle I can visually see and feel my shiter lifting upwards. Depending how hard I accel is how much higher it will move. Now I am 100% sure this is not normal cause it didnt do it before, and my previous TA did not do this either. I searched and am fairly sure my trans mount is bad. Previous owner said he put in poly motor and trans mounts, but apprently its bad already? Does the difference in vertical movement based on throttle % make sense as to a bad trans mount? Also Ive only tested this once as I am afraid to get on it, but when I got on it pretty hard and let go of the gas, I heard a thud.
Kleeborp the Moderator™
I've had my poly mounts in for years, and have never had my shifter do that...now with the rubber mounts, it moved a fair amount, and I did get the occassional thud when launching at the track.
Get under there and verify whether or not the mounts are actually polyurethane...I'd be very surprised if a poly transmission mount actually failed, but it could happen. The rubber mount I replaced was ripped, and caused my issues that the poly mount fixed.
ill take a look tonight, wasnt quite sure how difficult it was but looks like an ez task
http://www.installuniversity.com/ins...y_mount_m6.htm
Thanks for the help guys, ill report back if I figure it out.
Job was easier then I thought. Went under there to remove the trans mount nut, the big 18mm one, and it was bearly on! Could unscrew it by hand. Torqued it down to 77ft/lbs and car drives normal again. The mount appears to be poly. Gotte say I can def feel the vibrations that people speak of when you get a poly trans mount, but im just glad the shifter doesnt move up when I get on it a little.
