What do I need to buy for converting my A4 Trans am to an M6?
Hello guys!
Well I own an A4 2000 Firebird T/A
I have the FLT T56 transmission which holds 1000+hp
The question is
what exactly do I need to change in the car?
for example: Dash, shifter, pedals etc...
note: My car is around 850rwhp with an 250 spray
waiting for your feedback!
Thank you!
The question is
Thank you!
Your going to need..
M6 pedal assembly
M6 trans crossmember
M6 upper console
Computer tuned for M6
And of course the obvious..
Master cylinder, slave, clutch and pressure plate and flywheel, pilot bearing, Flywheel and pressure plate bolts and read the stickie in this thread. I'm sure i have left something out but thats it for the most part. Good luck
M6 pedal assembly
M6 upper console
A good clutch with that power. I switched mine from an A4 to M6 years ago. It is not actually that difficult. You will need to cut a bigger hole for the M6 to fit were the A4 shifter was at. The pedal assembly could be hard to come by.
