Clutch petal sticking along with weird noise
Hey guys,
When i hit the gas hard and shift, my clutch petal feels sticky and takes a while to come back to the original position. also, when driving it hard, i hear/feel almost a grinding or slipping.
Do you think these two are related? maybe bad hydraulics, slave cylinder or clutch itself?
Thanks
Thanks
Mine does the same thing. When I drive it hard the pedal sticks to the floor. I havent done anything about it yet, I'm just waiting til I get another clutch and slave all at the same time.
I've been having this issue for a long time in my 2000 TA as well as my brother in his 2001 TA (sticky clutch pedal, hard to get in gear at high rpms). Weve done everything under the sun, bled, bled, bled, replaced slave, replaced master cylinder, drill mod, high temp clutch fluid...nothing has helped. From the years of researching on tech we have come to the conclusion that in our cases it is our weak stock pressure plates not being able to let go at high rpms. We will both be getting Diamond stage 2 clutches in the future.
As for the grinding/noise during acceleration I don't know.
