Clutch slipping or?
Clutch slipping or?
I can be driving around and my clutch will act fine. But as soon as I go WOT it'll start jerking really bad, and sometimes my clutch will stick to the floor or it will barely have any clutch left. Any suggestions?
If it is completely done then it will do that, eventually I think that will happen in his case as it gets glazed more and more. If it is slightly overpowered then the clutch will be slipping at peak power and the extra heat will cause the diaphragm springs to be weak and the clutch will not disengage as the pedal gets soft from the fluid boiling. High temp fluid helps, but again it's only a band-aid as is removing the assist spring to take tension off and help the pedal return.
