trying to find problem help
Old 09-25-2011, 08:00 AM
atkinsson's Avatar
Default trying to find problem help
Ok I got a cam only SS my m6 has been rebuilt and I got a monster stage 3 clutch in it .. now my problem is a vibration and meshing can't seem to pin point noise. It hapens when I press clutch in and move car if I leave it in gear with clutch in and come to a stop the noise starts and vibration but if I throw it to nutral noise stops. And some times blocks me out of outing it in another gear if I'm at a stop.for example if u reverse out drive way leave clutch in to stop it vibration starts and I try outing it in 1st its like blocked and then let's me in .. any ideas I would be glad thanks o ya still got original pilot baring but can't be that don't add up.I don't think.
Old 09-25-2011, 08:27 AM
85MikeTPI's Avatar
Your clutch is not being fully engaged.. You need to (re)bleed the hydraulics or check if you need to shim your slave. How many miles on the clutch breakin ?
Old 09-25-2011, 09:46 AM
atkinsson's Avatar
Like 300
Old 09-25-2011, 09:47 AM
atkinsson's Avatar
And its been working fine for about 1and a half years u think its still that
Old 09-25-2011, 09:49 AM
atkinsson's Avatar
Is there a write up on that . Never have bleed that,never have don't it
Old 09-25-2011, 05:12 PM
jmd
jmd's Avatar
LS1Tech 20 Year Member
Post
https://ls1tech.com/forums/manual-tr...l#post13837919
Old 09-26-2011, 08:44 PM
atkinsson's Avatar
A lot of people r telling me its the pilot barring
Old 09-27-2011, 08:29 AM
85MikeTPI's Avatar
You won't know until you pull the trans out.
Quick Reply: trying to find problem help
