General manual transmission Question
Old 10-02-2011, 08:00 PM
My2kz28's Avatar
Default General manual transmission Question
Ive got a 90 toyota sr5 as my DD. I noticed my truck wouldn't go into 1st very easily, then a few minutes later it won't go into gear. Got it to into reverse, but then the truck wouldn't start. I used the clutch start button some toyotas have and it started but the truck was wanting to move backwards with the clutch in. What do you guys think? Does it need a new clutch or does it seem like something else? Could the clutch be ok and the trans needs fluid?
Old 10-03-2011, 06:33 AM
garys 68's Avatar
If it's moving with the clutch engaged, the clutch is not fully released. I'm assuming it's a hydraulic throwout, try bleeding it.
Old 10-03-2011, 07:22 AM
My2kz28's Avatar
It moves as i try to shove it into gear..with the truck off i can push the clutch pedal in and row all the gears. But i cant turn the truck on without using the clutch button they have
Old 10-03-2011, 09:12 AM
thesource's Avatar
Sounds like a clutch hydraulic issue.
