T56 Leak (PICTURES)
T56 Leak (PICTURES)
Ok, so my transmission has been leaking, its coming from the bellhousing/main body, but it doesnt run up the sides.. the silicone that was there wiped off easily.. so maybe that was it? also I have some leak coming from the small slit between bellhousing and the block.. i would assume its oil? but its kinda gritty? maybe its just more dex3 but its covered in brake dust? or is it engine oil?
Well, I would suggest that if you smelled the oil it would either smell like tranny fluid or engine oil. Thats one way to figure it out.
But, unfortunately considering that the leak is coming from the bellhousing area that the tranny needs to come out for inspection. It looks like ATF in the photos which suggests a leaking front input shaft seal. But, without having it apart it is hard to say.
g
g
g
g
having a buddy come over later and see whats going on with the potential oil. im gonna drain the fluid now and get the driveshaft and what not out.
another newb question.. what is this suspension piece going from my transmission to my rear end.. is it a torque arm? i have no clue, sorry for being dumb lol.. also.. why is the stocky y pipe attached to the trans xmember? lol.. gonna have it pick up an o/r y while im doing all this, this stock one is soooooo restricted its crazy.. its almost flat lmao
