clutch or trans
Old 10-09-2011, 08:53 AM
busa317's Avatar
Default clutch or trans
sitting in the driveway in N i hear a rotational noise comming from under my car with the clutch in it stos
also i can only shift into 3rd smoothly if i put the car in N first then 3rd and sometimes 4th
however I can not downshift from 4th to 3rd it makes a horrible grinding noise
i have bled the system several times i dont think that is my issue
any input
Old 10-10-2011, 09:37 AM
busa317's Avatar
So basically if im driving and come to a stop vehicle in n and and just push the shifter to 3rd gear something is still moving anybody have any idea and i still down downshift into 3rd gear
Old 10-10-2011, 10:11 AM
SPEC-01's Avatar
I want to make sure I understand your situation so please confirm:
If you come to a stop with the car in neutral and then try to select a gear it is difficult.
Does this affect every gear? Do you notice any difference if you pump the pedal (i.e. does it make it easier to select a gear)? Let me know and I will be happy to assist you further. Thanks,
Old 10-11-2011, 08:43 AM
busa317's Avatar
Default 3rd and 4th
pretty much its just 3rd and 4th gear like something is moving inside the trans any other gear is fine its just those 2 gears
if im driving normal i can shift from 2nd to 3rd if i put the car N for about 2 seconds and it doesnt grind but if i were to shift normal it will grind
Old 10-11-2011, 09:00 AM
SPEC-01's Avatar
This sounds like an internal transmission issue: synchro, fork, ring, etc...
So, it is time for a tear-down and rebuild!
