personal opinions: how difficult was your t56 rebuild
Old 11-01-2011, 10:31 AM
09jyounger's Avatar
Default personal opinions: how difficult was your t56 rebuild
I've seen some very detailed rebuild threads, but how difficult was it for you to tackle the rebuild in your garage? I've got the winter to do it and I'm debating on giving it a shot.
Old 11-01-2011, 07:03 PM
DAVESS02's Avatar
Not bad. You def. need to take your time and get the bearing clearances right.
I'd also make sure you check the clearance between each gear cone and blocker ring as well as make sure the gears spin freely on the mainshaft.
Old 11-01-2011, 07:55 PM
Blwn_by_Twins's Avatar
It was simple. I made a phone call, read some numbers, and a week later my rebuilt trans was here.
Old 11-01-2011, 10:06 PM
thesource's Avatar
Not super difficult but also not something I would recommend unless you are pretty mechanically inclined. Over the years I have seen people do them on their own with good results but I've also seen a lot that ended up worse off after a rebuild than before it was touched.
Old 11-02-2011, 01:54 AM
jmd
jmd's Avatar
Depends on what you've done before.
First off, read the downloadable rebuild guide from TTC in depth.
Then go back and look at those threads.
If it makes sense to you and you know what "set everything aside in the order removed" and "installation is the reverse of removal" mean, then you may want to try and tackle it.
Old 11-02-2011, 11:31 AM
09jyounger's Avatar
Sounds like I might give it a shot. I'm pretty mechanically inclined and luckily for me I have a guy around who's experienced and can help me if I have any questions.
Old 11-02-2011, 01:10 PM
Jr.Samples's Avatar
Good luck to ya brother. I hired this one out.
Quick Reply: personal opinions: how difficult was your t56 rebuild
